Panasonic inverter -Power factor protection
Had quite a few call outs (about 4 in the last 2 months) for inverter split systems not working. These have ranged from Daikin, Mitsubishi and now Panasonic. All of these systems have so far been the victims of Gecko's crawling into the outside control board enclosure and getting fried by the high voltage produced in these systems.
The Daikin in particular almost went up in flames, with almost complete destruction of the board (and the gecko), luckily no other components or plugs were damaged.
The latest suspect is a Panasonic Inverter (CU-E9CKP5) It is giving an error code "F90" and corresponds to "Power Factor Protection".
I went outside and took a look and a cockroach had made it's home under one of the IC's bridging out two of the legs, but it had not fried, nor could I determine that it had been burnt due to the natural crispness and colour of the cockroach - although it's head did seem to be missing...
I removed the offender and tried the AC again, still comes up with the same error code.
Nothing else on the AC looks suspect, I'm on the verge of ordering a new card but just thought I'd see if anybody would know where the Power factor correction circuitry would be... I assume the outside board cause of the ****y, but I could be wrong.
Cheers for any help and has anybody else had problems with wildlife with these inverters running high voltage? If not why me?!
Sorry bout the essay
Re: Panasonic inverter -Power factor protection
Yep lots of them up here,
Pretty common to see geckos and lizzards fried on the outdoor p.c. boards.
Mice/rats normaly like to craw up the paired coil when the hole isn't sealed and chew the crap out of the indoor wiring.
Even heard that the fugitsu inverters make the same sound as a mating green tree frog that attracts them, and yes again, get fried on the outdoor p.c. board. What a way to go.:p Under warranty of course.
I referred this customer to a panasonic dealer.
I rang panasonic and they would not give me any info.
F90=PFC control=• Voltage at PFC
Check you have correct voltage 240V ?
Replace Board ..
Replaced a few with the same problem ,
nothing visable anywhere but the board was dead...
