We like to install a colling store for vegetables ( iron, tomato..) . But This is the first time we do that. Pls, Anyone can show us how to choose compressor. Thanks :rolleyes: :D :eek:
Hi thoist,
You have many things to do before you select the compressors.
If you can share some more details we may be able to help.:cool:
- Determine the storage conditions required (temperature, humidity, air flow, etc)
- Determine the cooling loads
- Select appropriate cooling coils
- Select pipe sizes and installation methods
- Determine system type (DX or liquid overfeed) and refrigerant
- Select compressor types for good operating economy
- Select condenser (and type of condenser; air-cooled, evaporative, etc) for your weather conditions and heat rejection requirements
Dear Thoist,
The vegetables that you propose to store, are they directly after harvesting, in which you would require pre cooling of the same for removal of feild heat.
Then what are the produces that you propose to store and for how long.
We are doing these fruits and vegetables pre cooling and storage, and as such if you can provide details such as stated above, we may help you.
With best wishes,
Thanks my friends, I will send you details later.
Best wishes !
