Loosing 17KW
I've been reffered here by a contributor to the uk.d-i-y newsgroup so thanks Pete C.
I need to loose an estimated 17Kw of heat from a water based coolant system that keeps the electronics of an induction furnace cool. Water protected by mono-ethyl-glycol is pumped round at 45 psi (3 atmospheres) and needs to be kept below 40 deg C.
I am looking ideally for a direct water to air solution ie a biggish condenser / evaporator unit and fan. This is a hobby project (yes I know I should be certified) so both space and budgets are tight.
If anyone in England is pulling out a biggish condensor unit or multiple smaller ones and would like to convert them into pictures of the Queen aka beer tokens then please get in touch. They don't need to be pretty cosmetically, but they do need to work.
I'm based in Bromley Kent on 020-8402-0355
Regards,
Andrew Mawson
