how to calculate cooling time needed?
I have a question like bellow:
At the beginning, the room temperature and ambient temparature is the same, for example ( 35℃ DB, 70%RH), I want 27℃ DB, 60% inside finally.
the given air conditioner is 10 Kw for example, the thermo transfer coeficient K is 2.4w/m2.c.
let's say the room size is 3m*3m*3m
how to calculate the necessary time?
Re: how to calculate cooling time needed?
the time need is : cooling capacity /air volum*delta enthalpy if your cooling capaciy can balance the room heat load
most people will reply like this, but, don't forget, it is a dynamic process, the heat will tranfer from outside to the inside, and will become stronger and stronger with temperature decreasing.
27143721,
Why ask the question if you already know the answer? :confused:
Originally Posted by US Iceman
27143721,
It's a test? :rolleyes:
The method also seems strangely familar to someone that you might know wambat. :D
27143721,
I don't know exactly the answer, I only know what is the problem if not considering carefully.
I think maybe some people know better.
by the way, what's the meaning of "wambat"?
27143721
what you say is right,it's dynamical process :)but you can estimate it by easier method at many occasions. Of course if it's a precision lab,you need to carefully calculate it and have a test to confirm it finally.
What I mentioned is only a clue for you; may be you can use some simulation program to run it
regards
LC
regards
LC
Do you know the software name to simulate? I know one called Micro-Vissim, but I can't get it.
coolpack is able to do this job. have a try
