Have an 9 year old bosch ff been brill but notice water collecting in handles of freezer both sides . Temps seem fine in both fridge and freezer. What is lifespan of appliance
check drain channel in fridge is not blocked
Yeah drain fine
defrost heater, freezer fan,no restricted airflow in freezer,drain tube clear,door, seal damaged
if water getting in freezer handle it can only come from the fridge, so if its a wet wall need to double check that the water when goes from ice to water is not dropping in to fridge compartment
