What is the risk involved when using a compressor built for 50 hertz when operated at 60 hertz. Can we get positive results.
aii compressors can run on both frequencies, the speed and capacity will increase by 17%.
Not all compressors can run on 60hz. You'll get increased speed and higher ampere. Motor temperature will be higher and can damage the motor over time.
