1 Attachment(s)
Modern NH3 Refrigeration Plants
:) Hi,
I have attached a photo of a NH3 refrigeration plant, this plant has two 150hp compressors fitted to a common oil separator and Low Pressure Receiver. This is a 5 year old plant, with the picture taken last week when I was on site.
The photo is a side veiw with the black insulated LPR on the left and the screw pack on the right.
All comments apreciated good or bad, I hope the photo comes out alright give us a shout if it doesn't.
:) Regards. Andy.
Re: Modern NH3 Refrigeration Plants
hey,
I am a finaly year chemical engineering student studying in the UK. I have my final design project which is due in two weeks. I am a bit stuck with this as I haven't got much knowledge on this subject.:confused: My project is to design a chiller with NH3 as the refrigerant. this chiller is used to cool a water stream that comes out of a condenser at 20 C down to 3C. I specified the temperatures of the NH3 stream to be -45 C to 15 C and calculated the flow rate. Anyways I just wanted to get some basic idea about the main components of such a system and thing that you think might be useful for my design. Gosh you would be a life saviour if you could help out.. thank you...hope to hear from you soon:)
Hi, ask :)
ask
hey,
.... so you have to cool water having freezing point at 0*C
...:confused::confused: why you decide to use ammonia with temperature of -45*C
.... can you make a sketch of your system showing where you think to have ammonia with -45*C to 15*C
... try to think about chiller with evaporating temperature of ammonia at 0*C ;)
BTW you should open a new thread with your question and not to use this one 5 years old:rolleyes:
Best regards, Josip :)
