Hi,iam A New Member To This Site.i Want To Know How To Make Cold Store Calculations For Freezer Units.:)
Try the Cool Pack ProgramQuote:
Originally Posted by HAROON
http://www.refrigeration-engineer.co...ks.php?catid=5
Kind Regards Andy
HI, I thank andy for contribution. Greetings.
Greetings and welcome to RE:)
Kind Regards Andy:)
High Andy;
Please write the site of Cool Pack Program again
Hi, Aboubakr Negm :)
Welcome to RE
Follow this link:
http://www.refrigeration-engineer.co...ead.php?t=6694
or use the following link:
http://www.et.web.mek.dtu.dk/Coolpack/UK/
Best regards, Josip :)
Before you start using software, do the calculations manually.
The loads are:
Wall transmission
Door leakage
Product pulldown
Product freezing
Product sub-cooling
Product respiration
Lights
People
Ventilation (if needed)
Equipment
Defrost heater
Cooler fan motor
Each of the above are well documented in plenty references.
One thing to be aware of.
If you plan to freeze the product, make sure that it is possible! The load tells you how many kW but not the rate of cooling. That's a much more complicated calculation.
I agree with nh3. One should get to the basics before using any software package. Principles of Refrigeration and Air Conditioning by RJ Dossat explains the procedure in detail.
A more comprehensive software can be downloaded free of cost from KeepRite webpage
