calculating the kw's my unit is doing.
hey everyone I need help calcualating how my kw's of refrigeration the new pakage unit I just installed is doing. The tradesman I work with has set it as my home work but I have lost one of my main tafe books and cant find any formulas. Can anyone please help me. All im after is the formula so I can work it out on my own. But we had 19.2 air on the coil 27.7 air off the coil with an air flow rate of 2350L/s. on heating of course. Sorry if this is in the wrong section im a newbie. Thanks for all your help
chris.
Re: calculating the kw's my unit is doing.
I have yet to know this forum policy about homework questions. Most of the professional forums on the net either don't allow it or have separate forums. Till the time I know it, here is the formula for you.
Take pains to remember this forever if you continue to be in HVAC. The sensible heat can be calculated by Q = 1.1xcfmxdT, where Q is rate of heat flow in btu/hr, dT is temperature difference in F.
Go and get an excellent and free unit conversion software called Uconeer from www.katmarsoftware.com
Good luck,
theapprentice
chris.
Watch out as one of your tafe teachers may be lurking here!!
Q=M x C x ∆T
where Q= amount of heat produced
M=mass of air flowing
C= specific heat of air
∆T=delta T or temp difference
google for more info there is lots around.
Go search the secondhand bookshops library for a copy of "Princinples of Refrigeration SI edition" by RJ Dossat it is indispensable.
