Re: Freezing room problem
2.5 bar means you are evaporating at -16°C, should be more like -30, around 1 bar.
Was it working before? Air/ non condensables mixed with the refrigerant? TEV been mucked about with?
True. But at 1 bar not even half of the evaporator is freezing so it doesnt even go under 0 degrees C.
There is no air or other gasses inside. I vacummed the system to -0.95 bar.
The owners says it worked before but from my point of view its kinda impossible.
I also believe that the TEV has been modified or the orrifice its too big, but it makes me wonder how it worked before.
I believe the next step is to removed the TEV check the nozzle and replace it if its too big right?
You did chsrge it in liquid state i presume
Perhaps the compressor isn't pumping properly. Might be worth doing a pump down test before looking at the TEV.
Ok can we have some model numbers of evaporator and condensing unit,what is the delivery pressure and temperature going over the condensor please
Yes i charged liquid.
I will go there again tomorrow and check compressor model, check high pressure and evaporator model( which i think i wont find since its kinda old).
Thank you for info for now. I will b
Return with more info.
In an average ambient,delivery pressure should be around250 psi,do checks on the compressor pump down the liquid to see if it achieves a vacuum,
