I have a portable fridge Snomaster with Danfoss BD 35 compressor.
It is not cooling below 11.7. Celsius.
What can the probable cause be ?
Coenie
Coenie
Please read the temp as -Minus 11.7 celsius
What temperature does it normally reach?
You say a fridge but expect freezer temperatures?
OK, understood.
Is the voltage to the compressor correct and is it running at the correct voltage?
Brian
It is now working as it should.
I was impatient and should have waited a bit longer for the cooling to kick in properly.
But thanks for the advise.
Coenie
OK, glad that there isn't a real problem.
