desuperheater / economizer
I would like someone explains me what are a desuperheater and an economizer, and how they work, where, why...? Iīve been reading but there isnīt much books in spanish about these things. Donīt worry to be very technical, iīve got time and a good diccionary :D
Re: desuperheater / economizer
Superheat -- could you tell me the details of your setup -- flow rate of pump- type of differential temp controller ??
My 28 year old York Triton water source heat pump finally died and I am installing a 3 ton unit with desuperheat -- I have an on-demand water heater with an old water heater as a pre-heat tank to supply the heater -- I am using well water ( 54 degrees - but slightly acidic) -- heat pump is about 15-20 feet from water heater and I plan to use CPVC piping
