Can heat reclaim be used on a 900 ton, 7 recip compressor, ammonia refrigeration system? If yes where can I get design help?
With this size of a system there may also be opportunities for additional energy savings, besides only heat reclaim.
Is this a cold storage warehouse or food processing facility?
This is the sort of work I do and would be glad to discuss your project with you.
soft drink bottling plant, 7 recip compressors on central refrig system,
25 SST, 96.2 condensing, max load 790 tons, total HP 850.
OK, thanks for the info.
How much heat do you need and what temperature is required? Is this recovered heat to be used for space heating or heating water for other purposes?
