leaking daewoo fridge freezer ERF 384M
Hi Guys,
I'm new to the forum and wanting advice on how I might fix my domestic fridge freezer. Its got a frost free freezer that leaks water out the front door seal every few days and develops an ice sheet at inside at its base. I'm presuming its something to do with the timing if the defrost but I wasn't sure. there is about a cupfull of water sometimes.
Any advice greatly appreciated!
ken
Re: leaking daewoo fridge freezer ERF 384M
Word Up Ken,
You need to check the drain isn't blocked at the back of the freezer somewhere (take all the drawers out or check from the back of the unit). While you're at it make sure the door seals are intact.
Cheers,
Andy.
