What is the most efficient hfc refrigerant? The lowest gwp?
It depends on the conditions. There is no such an answer. The lowest gwp is for R744
Hi NoNickName,
First, to be clear R744 in not a HFC andQuote:
Secondly if you are including R744 - R717 is the lowest (and most efficient). :)
R717 is not the most efficient. Is the one that carries more heat per mass, not necessarily the most efficient. That's why I asked for the conditions.
Condition's aside, R718 has the lowest gwp.
not true, water vapour has a considerable global warming effect
Lowest gwp should be R-728 at 78.084% / R-732 at 20.947%
The official GWP of water is unknown because it is dependent on temperature and phase. When condensed, it is opaque to sun radiation and its GWP is negative and is called albedo.
When not condensed, it is transparent to infrared radiation at high frequency (from sun) and opaque at infrared radiation at low frequency (from earth).
GWP of water is therefore undetermined, but very high at uncondensed phase.
desA got it right. Air has the least GWP.
Air does have the lowest GWP by numbers but water evaporated by the sun has no GWP as it "GWP" is only calculated by non natural processes - don`t try and argue as most folk do that there used to be no sun
I live around many farms with lots of cattle sure methane has a specified GWP but not from naturally produced methane
It Is measured ONLY on man made contribution
Facts are facts
regulations and the real world differ
NEXT!!!:)
You are taking it too seriously
No I am taking the facts and to be fair they are not my facts but those of the Kyoto protocol
I must stress that is a fairly light comment from yourself
Yikes! sorry I asked that question.
Reason was the company I work for built it's second CO2 rack.(subcritical).
The top cycle is 134A.
Was wondering if there was a more efficient refrigerant they could have used in that application.
Considering a middle temperature of -10°C, yes, there is a more efficient refrigerant.
http://images.zaazu.com/img/vomit-bo...652-medium.gif
Peter_1
Until of course HFO1234yf starts to be used!!Quote:
R134a, lowest GWP for commercial appl.
Interesting. I have never seen 134A used in a Rack application or in a condensing unit. Only self contains.
