Hi guys, I hope you are well today. I have a problem with my AC.... it won't start when I start it from the remote control, it only starts, when I start it from the on/off button on the indoor unit. When I've checked the fault codes it gives me C7 which is FRONT PANEL OPEN/CLOSE FAULT. What is causing this? Can this error be cleared from the memory, or this is some damaged component? :rolleyes: any help will be greatly appreciated.
I suppose the problem is in the vertical Louvers, as they are not turning when I'm starting it..
Any additional info you may need to diagnose the problem, just ask :D
