PUHY-P250YMF-C (r407c) TEST RUN
I'm facing a strange problem A system consiting of 6 ICs a BC and a OC heats only when I impose TEST RUN form SW-3. The pressures during TEST RUN are 56psig/260psig. If I switch the ICs on, the compressor starts but after a while stops eventhough the coils of the ICs are cold. The compressor works for short periods of time and the indication standby doesn't go off. Any sugestions?
Re: PUHY-P250YMF-C (r407c) TEST RUN
Why have you got a BC on a Heat Pump System when you should have a Heat Recovery OC ?
