Aİr to aİr heat pump unİt(rooftop) desİgn
Hello guys,
I have a question.
I design air to air industrial heatpump unit(Rooftop packaged units).
We use constant speed compressors and thermostatic expansion valves.
I have doubts to size and calculate the indoor coil because ıt works as an evaporator and a condenser.
If I size it as a evaporator then ıts inside volume will be little to work as a condenser.
Because once I experienced this situaiton and the pressure goes to so high quickly in the heating season. I think this happens because of insufficient volume of indoor coil.
What can you advice me?
