Re: Reefer Monitoring System
I've found a video similar of what I want to do.
https://www.youtube.com/watch?v=FwkcRzjruV8
Hello,
Did you find any solution for this?
We are interested on doing the same.
Where are you from?
Regards,
José
Can you please tell if you could find the protocol of communication with Microlink 3? Thank you.If there is something to help write to the mail german11vn@gmail.com
This external retriever port requires a protocol specific to each reefer manufacturer and those manufacturers only provide that protocol to some companies like Orbcomm, Emerson, RTE and some others Each of those companies has a commercial solution that allows shipping lines and terminal operators to access and control reefers remotely. It can be backwards engineered I'm sure but it won't have the support of the OEMs. I have a lot of experience with the Orbcomm solution which now owns the WM/Mark-It Services technology
