Hello, could anybody help me out on a trane scroll compressor, i need to no the tecnical information about a trane scroll with the model CSHA 150KE working with R407c, i need to replace it but donīt want to use trane , but an equivalent
Some info here...
http://www.atilimsogutma.com/Folders/Trane.pdf
and here
http://www.americanhermetics.net/ass.../scrollsnc.pdf
also here
http://www.trane.com/commercial/uplo...tDALLAS.OK.pdf
Hi :
trane scrolls are very expensive !that is why we use maneroupe comps as a replacment or even copeland ,the only problem is the minor change ,u must make on the pipe connections.
we have done this many times.
U should however clean the system very well after a burnout,to prevent this from repeating itself!
Bitzer compressors are another more economical option
Those compressors are badge engineered for Trane. Some research will find the identical compressor, much cheaper (or it was last time I did it). Sorry but I can't recall for sure who makes them - might be Danfoss?
If it's on a manifolded circuit and it's burned out then it's generally best to replace both compressors if you can persuade the client to do so.
By the way, they can be bought alrady manifolded on the sub-base from the manufacturer - makes it much easier! ;)
Actually the whole design is Trane. they sold the lisence to produce them to maneurope. That company was taken over by Danfoss. But the bottom line stays, it's a Trane designed compressor.
Well, of course. But I figured if I explained all that in my post, it'd get confusing! :)
All well in Holland, I hope?
yeah, all well here! u?
Good thanks. Beginning to cool down at last, but 95% of our work is maintenance so still busy. Will PM so we don't hijack the thread.
scroll compressors are manufactured by trane at its plant in Monterrey Mexico
