All hello!
Decided to assemble independently refrigerating unit, at present collected the sixth. Look, estimate, can what offers or remarks will be?
All hello!
Still photo
nice job- fit a solenoid valve on the oil return so when the unit is at temperature and pumped down it doesn't constantly cycle on lp
usually a panel mounted isolator with interlock to ensure its isolated before opening the door- sorry, I have a habit of snagging systems:confused:
inverter drive on the compressor, panel mounted so you can see loading/frequency- also this will have loss of phase protection
Excellent layout, plenty of space to work on.
al
Inverter costs much. Protection against jumps and on a phase is established to tension (To the relay of the Russian production RNPP-311P - very good, convenient and not expensive)
Tension relay RNPP-311M
