hello everyone.would somebody help me distinguish compressor hp or tons by just looking for the lra. conversion to tons or hp?
You cannot find compressor cooling capacity from LRA. Do you have any other data. Compressor manufacturer, model number, application conditions.
If you can read the LRA then the nameplate should still be attached.
What nike123 says plus do you have a picture?...what color is it?.......semi or hermetic?
Might be able to get you a SWAG theory on the size.
[quote=faquiambao;93528]hello everyone.would somebody help me distinguish this copeland compressor for walk in freezer.Model no.Ead2-0200-cab-200. with 230v an lra of 58.0, rla 8.4, 60 hz. how many horepower is it. thanks to everyone.and is it still avialable in the market . how much does it cost.
[a good day to everyone) i have here a Manitowok ice maker for repair.Model no. QY0804A. My problem is the harvest takes so short in heating. if thin ice its ok, but if adjusted to thick ice .it won`t harvest.but the reverse heating process works but just a short time.how can the reverse heating process be adjusted to longer period so it will harvest even thicker ice. is there any part that need to replace? can any body help me .thanks.
