Has anyone heard of Condensor Fan control using single speed fan but using a 'wave clipping' technique to vary the fan speeds ?
What do you mean by 'wave clipping'?
All speed control modify the supply voltage / wave form in some manner.
Many of them use Triacs. Other forms use Hall Effect or stepping motors.
Some of the Japanese makers use a method that eliminates whole wave forms in a regular sequence.
You pays your money........
________
buy silver surfer vaporizer
Yes, it uses Triacs - but I'm not sure how that works except that it clips the waves.
So can I use a normal light dimmer switch to control a condenser fan ?
Thanks Marc - Is the Diac like a Diode ?
A Zenner diode will only allow a set voltage to pass. On a 12 volt zenner, any voltage above 12 volt will be denied. These are used where a set voltage is required, say in a power supply or as a reference voltage.
Let's me thinks to a varistor. Each tech of us has allways some varistors in his van.Quote:
On each power supply to an expensive device such as electronic thermostats, PCB's, electronic transformers for halogen lights.... we place varistors - which are very cheap (less then 1 € or 1 $) - to protect them for overvoltage.
It protects them also if the common (or neutral) fails for some reason (here we go again) in a 3 x 380 V +N.
