I have a customer looking for a replacement mechanical seal for that and i have no idea what will work. How do you find seal replacement information for these?
try JOHN CRANE OR BURGMANN, they can to rapair your shaft seal or try to do it with good turner . composition you can find en shaft seal manuals.
Hi, I'm sorry but I do not know the part number 53M0602G02 do not know what the compressor.
I know only 534M0602G02, it is a screw Frick xjf 151st
Is this correct?
Josef.
Josef,
That is probably the right part number, it looks like one of the digits was dropped in the translation. And they just told me it is a Frick 151 but they didn't include any letters in the model number.
Bear
Why do you not want to seal the Frick?
Josef.
Thanks ping, where can I find those manuals?
Bear
Josef,
I'm not sure what you mean.
Bear
look at:http://www.mechanicalseals.net
http://net.grundfos.com/doc/webnet/w...haft_seals.pdf
Best regards, Ping
Hi Ping,
Thanks for the links. I am familiar with mechanical seals, that's what I do.
The issue is identifying which seal will do the job so I need a type, shaft size, face materials, elastomers, etc.
Is there a place to find that information for that Frick?
Bear
Frick information is very closed, i had worked in York about 10 years and all information is very limited.
Hi Ping,
Thanks for the effort. I do appreciate your willingness to help.
Bear
Oroiginál parts Frick (JCI), otherwise the problems.:mad:
Josef.
