American Standard Air Handler Install
Hello All, few days ago we replaced our entire Central AC unit. New Heat Pump and Air Handler. Older unit was over 12 years old and finally had ***** leak in the evaporator coil.
We went with Silver 14 Heat Pump (2.5 Ton) with matching Temp4 Air Handler.
Most folks told us key to long lasting HVAC is the install. Our older Air Handler was perfectly aligned with all components. However this new Air Handler seems little off.
Should this be a concern for us? Air Flow maybe getting impacted since bottom components doesn't seem to align too well?
http://i1298.photobucket.com/albums/...psziboqf5z.jpg
