Noise induced hearing loss damages
A man has been awarded £6,000 compensation pay out after he contracted noise induced hearing loss as a result of being exposed to noise from power tools and engine noise. As a result of being exposed to noise from air tools, sledge hammers, steam cleaners, air lines, grinders, engine noise and drills he developed hearing loss which is irreversible and causes him to have difficulties in understanding conversation. His lawyer said he was never warned or advised about the dangers of noise induced hearing loss or provided with any protective equipment.
Re: Noise induced hearing loss damages
Hi Abe
Do you reckon we could get payouts for Tinnitus?I was never told about working in plantrooms without ear defenders until it was too late.
It may have been due to excessive nightclubbing,but if i can claim against anyone i will blame it on work.;)
Go see a personal injury solicitor
Only way to prove it is a hearing test before you started employment, and then another test proving you have lost hearing ability. Even then, you have to somehow prove and supply testament that you didn't do anything outside of work to cause it like loud music, and prove that you had inadequent training and equipment.
Without a "before" and "after" test you can't prove you lost anything.
Even with a "before" and "after" test you'd have to prove that your employer was negligent. If you can't prove they were negligent, it's fair to assume you lost your hearing due to out of work activities or age.
That's the basics, even then you'd been fighting uphill to prove that you didn't work in unsafe conditions volutarily, ie didn't wear protection by choice etc, so you might need coroboration from other employees etc.
Sorry Paul i could`nt hear you! Could you repeat that?
Chunk,
You may have the sound turned down too low.:D
paul_h
Only way to prove it is a hearing test before you started employment, and then another test proving you have lost hearing ability. Even then, you have to somehow prove and supply testament that you didn't do anything outside of work to cause it like loud music, and prove that you had inadequate training and equipment.
That's the basics, even then you'd been fighting uphill to prove that you didn't work in unsafe conditions volutarily, ie didn't wear protection by choice etc, so you might need corroboration from other employees etc.
What normally happens in these cases is that, after a certain time, the legal eagles decide that it would be cheaper to come to some sort of deal rather than keep on spending money. hence, the poor guy who has lost or is in the process of losing his hearing is given a relatively small sum in settlement of the claim.
Without hard evidence in these cases, which is very difficult to obtain and prove, most cases would not end up with large payouts awarded by the court.
As one solicitor once said to me " it's not about right or wrong, it's all about who puts up the best argument on the day in court"
Problem always seems to be - how to get to court? A long, tortuous and expensive route.
