Which formula should i use to measure the capacity of a ducted unit running in heating.
I can measure the air quantity and the temp on the return air grill and then the temp of the supply air.
In metric please!
In metric please!
Would the following be correct:
Kw = l/s (air velocity) x kj/kg K (SHC air) x kg/l (air density in liters) x (air temp on coil - air temp off coil)
Therefore
Kw = l/s x SHC x air density x temp diff
or
Kw = cubic mters air/hour x SHC x air density in cubic meters x temp diff .all divided by 3600.
