how the split unit consume less energy then a window type unit
hi every one
i came to know that split unit consume less energy then a window type AC boths are having same capcity
please give some solid reason
thanks a lot
jahangir ahmad khan
lahore pakistan
Re: how the split unit consume less energy then a window type unit
Window rattlers are built down to both size and price.
Modern splits has various technologies, like inverters, built in to them just to increase their energy efficiency.
Generally, the split would also have larger coils.
Window air conditioner of 1.0 TR capacity with rotary compressor draws 1100watts while hi wall split unit of 1.0 TR capacity draws 1220 watts for two star rated units.
Power consumption of 4star rated units are identical with that of window air conditioner.
Therefore, I believe window air conditioenrs have lower power consumption.
Visit www.bluestarindia.com
Are the capacities really equal? Did you measure them?
hi GXMPLX
no i'm not measure them
but written on the sticker pastae on the out door unit boths are same capcity 18000BTU/hr
in my mind becuse the compressor and condensor in a single box thats why it consume more energy compressor working more.
what u think?????
best regrads
jahangir ahmad khan
lahore pakistan
Actually since the compressor, condensor and evap are located in same box, power consumption should be less due to reduced refrigerant piping lengths.
If pipes are proper selected, then the nit will not consume more power. Every VRV/VRf should then be the worst made AC- machine ever and this isn't so.
Hmmm before I say anything, I would like the model and manufacturer of each compressor.
I think there you could have efficiency differences that could be larger than pipe losses (unless one system is too far appart).
If they had the same compressor, yes piping and different operating conditions would explain differences unless one of the compressor is worn out.
Window units have smaller fan at the condenser side, the condenser is a bit smaller, condenser is up to 4 rows deep, thats where the differences are
chemi-cool
With smaller condenser so should condense worse.
You have higher thermal losses in compact design.
Smaller evap means you evaporate lower.
So you won't see me jump into conclusions too fast!
I think compressor differences could explain more.
But I am not saying you are wrong ... You see even a LADA has been down those roads!
The difference would be due to the size of the evaporator and condenser. The size and ratio of these is important in getting the maximum efficiency. This can be acheived easier on a split system. The window/wall unit has a smaller evaporator and a lower evaporating temperature. They also use the same motor to drive both indoor and outdoor fans, so are restricted as to the airflow and head pressure control.
vijay_study
also the last window unit i purchased also had the liquad line looped thru the evaporator condensate tray adding more subcooling surely that would help to make it even more efficient
or is the difference is that the window rattler has only one fan motor?
Window shakers have evolved along with everything else. If the energy consumption is not currently competitive, it eventually will be. And along with the lower price they will have the huge advantage of being easy to install.
