Display Freezer not cooling
I have an upright display freezer controlled by an eliwell IS972LX.
It won't cool down.
The compressor and fan are running. It sounds like a solenoid/switches are energising - but no cooling. No alarms are showing on the controller.
Could the controller be faulty? Short of gas?
Any ideas would be much appreciated.
Cheers.
Re: Display Freezer not cooling
If the compressor and fan are running then theres no diy way out of it.Call your local engineer
hoover the crap off the condenser coil - (hot bit )
Do you have a make/model of the unit or a brand on it?
hagen dazi!:D
1mikeefc1
Turn it off and take the bottom panel off then blow out the condenser it will be stuffed up even though it may look clear, the 5/6 I've cleaned this year have made a right mess in the shop even though I tried to cover stuff up. Give it 30 mins off to settle all the dust down and turn back on.
