Octopush Technology Controller 8320-220V Parameter List
Grup Sıra Parametre BirimMin Max Default Fan 1 frc Y/N No Yes NoFans on with the compressor 2 fst °C -55 110 15Fans stop upper limit 3 Fdf °C 0.1 10.0 3.0Fans differential Cpr 4 Cdf °C 0.1 10.0 3.0Differential 5 Scd min 0 10 1Compressor delay after start up 6 Sad min 0 10 1Delay for compressor switch on 7 Hst °C -55 110 15Maximun allovable temperature 8 Lst °C -55 110 -10Minimun allovable temperature Dfr 9 Dft °C 0 100 25Defrost end temperature 10 Ddu min 1 60 35Maximum defrost time 11 Dt NDF / HG / AIR / EL 0 3 3Defrost type :0: No defrost /1: Hot gas/2 Off cycle/ 3:Heater elements 12 Sdd hr 0 24 1Defrost delay on start up 0: Defrost cancelled 13 Dit h 1 24 6Defrost interval. 14 Dct Ct/Rt 0 1 1Defrost interval/: 0: Compressor on time /1: Real time 15 Drt min 1 10 10Drip time after defrost Alr 16 Hrt °C 1 10 3High temperature alarm 17 Rtd min 1 240 30High temperature alarm delay 18 Lrt °C 1 10 -3Low temperature alarm 19 Ad min 1 240 180Alarm delay at start up 20 Dad min 1 240 60Alarm delay after defrost Cfg 21 Set °C Lst Hst -5Set temperature. 22 Tpc °C -12.8 12.8 0Room sensor calibration 23 Epc °C -12.8 12.8 0Evaparator sensor calibration 24 Out Vers 0 0 20Octopush Version 25 Adr Adres 0 254 1RS485 com address Dsp 26 Tsd 0/0,0 No Yes YesDisplay resolution: Integer / Decimal 27 Dts def/set/t 0 2 0Display during defrost: Def / Set valuei / Room temperature 28 Ptd t/e/c 0 2 0Temperature displayed: Room / Evaporaor / Condenser
