Re: Daikin super inverter
Have you checked the temperature sensors?
Yeah I've changed the thermistors but again from the redundant unit.
Craig Johnston
Whenever I arrive it is in a e4 fault (low pressure) when I reset the unit it works fine but the condenser freezes up very quickly.
I assume that you are in 'Heating' mode?
Yeah. It's on a biddle door curtain so the shop would kill me if I put it in cooling.
Do you have a full model number?
Tested the low pressure sensor already. Mod rzq250c7y1b biddle is UK.city m-200-dk-f
Have you checked that the Biddle unit is clean and with the correct airflow.
Yeah filters and coil clear with great airflow
What is the outdoor temperature?
On page 24 the piping diagram shows an expansion valve feeding the outdoor coil in heating mode. This may be starving your coil and causing the low pressure fault http://www.daikintech.co.uk/Data/Spl...B_Databook.pdf
Cheers Frank, thought it was the expansion valve. I'll replace it and keep you updated.
