hi
every body may ask how to install the fan in desktop pc
how to choose between make it discharge or suck air
so i found the best way to install fan
as in image below
Attachment 10081
hi
as in image below
Attachment 10081
it sucks the air through the aluminium heat exchanger
I assume the blue arrows are the cold air and the red arrows are warm air. What are the green and the pink arrows indicating?
Also why does your computer have many more parts inside it than my computer? I'm worried I might be missing some important parts.
got a few hard drives there!!- cabling is restricting the inlet fan at the bottom.
Attachment 10083
number will mean the fan suck or discharge air
number 1 fan discharge air out
number 2 fan suck air in
number 3 fan suck air in
number 4 fan suck air in
number 5 fan discharge air out
number 6 fan discharge air out
number 7 fan fan suck air in
you have 3 fans discharge air and 4 sucking air, i think you should have one more discharge fan and all will be fine.
Are all the fans the same size?
yes the fan are same size
the photo show you not to install whole fan
but show you the best way if you want to added fan to your case
Seven fans...wow!!!! If you need that much air movement maybe it would be time to go liquid cooling.
just be eco friendly and leave the side cover off:D
its too bad if you open side cover
specially in my country
because dust and sand storm happen oftenly
ROFL... The above comment made my day... :D
