Cleaning SS Hoses ??
I was recently given a nice set of SS hoses that I will be using for evacuation and deep vacuum. They hold <50 microns for an extended period so they have no leaks or moisture.
I have blown them out with N2 but still see oil at the fittings. I have no idea what this oil might be and would like to get them as clean as possible.
Best method??
Re: Cleaning SS Hoses ??
I use a can of automotive brake cleaner, the type a mechanic would use to degrease new brake discs and such for light degreasing. Be careful though as it is extremely flamable.
Jon
I am just concerned about any residue that different solvents might leave behind.
At 30 microns vacuum for an extended time I would think that any oil would boil out? When the pump is valved out the rise was only about 6-8 microns in an hour. This was with all 4 hoses connected. This tells me that there wasn't anything boiling off?
They are probably fine, I am just very anal about contamination.
Hi Alan,
I'm pretty sure that brake cleaner leaves no residue or it would be no use in cleaning brake discs/rotors and drums, its also very volatile and will evaporate at room temp so i'm sure it will evaporate in a vacuum.
Or you could run some clean refrigerant through you vac lines if they will take positive pressure.
Jon
