I'm new and a bit weak with English so if you can a little help.
if anyone tried to bury the external capacitor from the split ac climate. Does anyone have such experience.
thanks
thanks
Hello Zdravlje, Why would you bury the capacitor? Maybe you mean the condenser but either way, no, have never ever thought about it unless it is beyond repair.
in our winter temperatures around -15, the inverter is expensive so I thought to take a constant temperature in the ground, and I have a lot of parts of the split system, so I thought I test something like that .... Google translation...
Zdravlje, i see what you want to do, to use the warmer temperature below ground level as a heat source for an air-conditioner. How far down would you have to go for temperatures to be around 0 degrees c? Over here, most of the year we are working to keep temperatures cool, so unfortunately i'm not much help... mike.
about 1.5m depth .. about 10 degrees for example, have already laid pipe but could not come from commitment to joint and fill the system ..
It may not gives you a positive solution... as the depth selected is not so deep...
