We are working on a new cold store facility & the height is 16 mts.
We are using two wall panels 12m+4 mt
There are many methods of putting up such wall panels one above the other.
I want to know what is the practical experience of members?
What is the width of the panels.
Is it filling a building if not steelwork around it would be vital
The Width of the panels is 1.2 mts.
The steel structure is proposed all around.
sorry, no experience above 12 m panels ...
size 11680mm x 220mm x 1176mm(installed in Guntur) selfstanding
(internal panel wall of SS material outside wall white RAL 9003
it was hard job ... those panels were quite heavy and very hard to install ...
cold room working temperature -50*C ...
.... definitely there are many possibilities to join 12m and 4 m panels ...
not sure what to suggest for sure connections would be covered with flashing internal and external and tight with silicone ...
Best regards,
Josip
