Hi Guys
Would appreciate if anybody has a copy of the above wiring diagram I could have. DOM is 2007.
Many Thanks
Gibbo
Hi Guys
Many Thanks
Gibbo
I tried to find it for you Gibbo!
All I have is the original ALS Manual which does have some Wiring details in it.
If you feel that is any good?
I can send it to you.
Many Thanks Grizzly
I have the IOM, having issues with EV driver / battery back up alarm hence the wiring diagram will try McQuay on Tuesday. Problem started with reading of 0 bar and 0 c temp. pLAN light was flashing found the driver had been replaced by site engineer but with wrong address on dipswitch changed the address then the alarm came up "ev driver battery error" alarm on main display. Changed the Carel EV driver, Carel battery module and battery from a working chiller on site but still showing the same alarm. Any help appreciated.
Gibbo
Got Me, my friend!
Good Luck, Maybe some of the more acquainted with McQuay Guys can help?
Cheers Grizzly
Try this;
http://airconservice.ru/d/1098676/d/...ad-ajynn-q.pdf
It is the air cooled version but some of the info might apply
Wiring diagrams page 105 onwards
Many thanks very helpful indeed.Well worth a rep point once I have figured out how I give it. Will have to ask Grizzly.
Gibbo
^^Just click on the Star icon at the bottom of the post.
Many Thanks Brian
Gibbo
