Re: Chiller BLUE BOX problem
Are you in a position to swap the controller over with another one?
It sure sounds unhealthy!
Is the control module from the original machine?
If it is a 're-cycled' board with re loaded software, there could be a prevent mechanism from its previous life causing the 'reset' occurance.
The software / control picks up an irregularity and forces a 'reboot'
Sounds like it'll need a new board.
The controller is the original one .For me this seems to be a software problem . No i don`t have a spare electronic board . Corect me if i am wrong : all the parametres are stored in the main electronic board no`t in the Pco display !
It could be directly related to the board it is plugged into.
If possible i would test it with another display or PCO controller.
Sounds like a software bug, but i'm sure Blue Box have more than one chiller with this software on it?!
Thus the possibility it is hardware related. Maybe contact a Blue Box representative for info.
And of course you are correct. The logic is all in the electronic board!
ciao tex
Per aiutarti ho bisogno del numero dell'applicativo software
Sorry
To help you I need your software application
