High pressure switch
Gents,
Does anyone know if you can buy a braized high pressure switch off the shelf. I've got a unit that's gone down due to a faulty HP switch and need one urgently?
I know you can get the danfoss dual HP/LP ones but not sure about the braized in ones?
Re: High pressure switch
These ones are not brazed, but close to what you are looking for. They are screwed directly at schrader access valve (you braze it where ever you like) and they have valve needle depressor built in. Easy to fit and exchange.
http://www.invensyscontrolseurope.co...t.aspx?id=3618
http://www.invensyscontrolseurope.co...t.aspx?id=3619
Hi Marc
Danfoss do a single pressure switch or a hp / lp with a brazed connection.
KP1 are the single range and KP15 are the dual.
I have a pdf which I will send to you because of its size I cannot attach it on this post.
Danfoss are readily available and just explain to your wholesaler or refer to the collective set of instructions for the relevant set of codes.
1 Attachment(s)
Thanks guys.
This is the type of HP switch installed t the minute. I'd prefer one of these if poss
1 Attachment(s)
Attachment 11625 1 in leeds! haha
Thanks to everyone that posted but I think HVACRsaurus has found what I'm looking for.
I'll probably order some of those that Nike123 mention to keep in the van as stock.
Once again thanks.
Reps all round (unless I have to spread the love)
Happy birthday for earlier in the week RB,
