1 Attachment(s)
Trane ECGCE205 Programming
Hello,
1994 Trane ECGCE205 2 Circuit, 4 compressor
I have recently replaced the circuit A controller board. After replacement it did not appear to recognise the circuit B module and would only run compressors on the A circuit regardless of the circuit selector switch on the B module.
This seems to be due to the new controller needing to be programmed, I managed to change what must have been the setting for the number of circuits and got both circuits to operate. I’m a bit concerned that I may need to set up other parameters and wondered if anyone would have a programming manual for one of these.
Attached picture is from an identical chiller on site.
Many thanks
