I am looking for the manual of Marco polo air drier model 5MP1600 and controller parameter's list.
Controller is Dixell IC121C.
Thank you guys.
Thank you guys.
Can't find an IC121 but found an XT 121, same thing??
http://www.dixell.com/linea58/downlo...-121C-D_GB.pdf
or try Dixell download site?
http://www.dixell.com/home/eng/
(You may need to register)
Thanks brian,
The controller is OEM, special parametrs for MTA.
I could not find the way to change them.
Apparently, Dixell is connected somehow to MTA, all the controllers have different functions.
If I cant find the papers I will put a different controller with a timer for the condensed water.
It only means to rewire the control board.
I installed a MTA drier earlier this year and I handed the manual into my office, if I can retrieve it I`ll email you a copy.
If you do fit a replacement controller you can always fit a timed solenoid condensate drain instead having to find a controller to enable the use of the original drain.
Regards,
Glenn
Thanks very much.
I will leave you my email in PM.
pass codes 4, 32, 69?
