Daikin heatpump
Hi was doing a service on a daikin air to water heat pump ,only problem I noticed was the large coil of refrigeration pipes behind the outside unit, I know the unit needs a certain amount of refrigerant (thus extra pipe)for correct operation but will the large coil of pipes have an effect on the refrigerant
All comments most welcome
Re: Daikin heatpump
If you give us a model number we "could" check the manual to see...
But generally, the unit should cope with even the shortest of piperun, normally they only get problems when the maximum pipe length is exceeded.
Perhaps the installer didn't bring his pipe cuter???
:cool:
Can you take some pictures and provide model and serial number too?
Re: Daikin heatpump
daikin usually req a minimum piperun of 1.5mtr - ad no i didnt install it!
Re: Daikin heatpump
Hi all , wish I had taken a few pics , daikin altherma split unit , inside unit is back to back with outside unit ,about 1.5m of pipe work (uninsulated ) when it enters the house ,must be at least 8m of pipe coiled up outside , or am I just being fussy
Cheers all
