Originally Posted by acb
Hi evreyone,
I'm having a few problems with a customers fridge, it is a criosbanc cabinet witha partially destroyed I.D plate, all I can get is a model which I think is D1A41 and a cond unit which is a Asprea model UT2178GK. The system runs on R404a and the customer assures me that the other engineer that has attented quite a few times recently has been adding refrigerant. When I connect my guages the suction press is just over 5 bar and the liquid press is 27 bar, the ambient temp is around 24 degrees c, the condenser is clear, liquid line burning hot, system has a 12ft long blower evap with a number 2 orifice, it has also bubbles in the sight glass, I dont want to add anymore refrigerant due to high liquid press, but I cant remove the current charge and recharge because I dont have a charging weight on the I.D plate can anyone please help, thanks. Alex Boyd:confused:
