SOS!!!! HOW TO calculate refrigeration system and choose refrigeration Accessori
HOW TO calculate refrigeration system and choose refrigeration Accessories?
some ones have ANY reference BOOK to recommend:confused:
Re: SOS!!!! HOW TO calculate refrigeration system and choose refrigeration Acces
Hi, ashp :)
Welcome to RE forums...
ashp
Purpose of refrigeration system, which refrigerant, what capacity......how we can help you:confused:
....the best for you is to search RE forums and for sure you will find a lot of posts about calculation of refrigeration systems and also a lot of links to free books and other things....
Telling you everything is not good for you, because you will not learn anything:rolleyes:...your homework you have to do alone...but always welcome to ask some specific things and someone here will be glad to help you;)
Best regards, Josip :)
Priciples of Rferigeration By Roy J.Dossat will give you good details of sizing Refrigeration systems.
System accessories are decided primarily on the basis of the application such as
@ blast freezer
# chilled water plant
@ cold room
@ brine
@ air-conditioning
load pattern also plays a part in deciding the accessories required etc .
Hi friends can somebody tell me how to calculate the refrigerant Kg in any refrigeration plant (ammonia plant)
you can study heat transfer if you wanna to know more
I would recommend Basic Refrigeration and Air Conditioning (I am getting old can not remember the Author, apart from there was 3 of them, US produced original is quite old but gets updated, at the end of each section, there is a Test
:o I trried use the Vilter Refrigeration Pipinh Data Manual, it was very helpfull, you have to try;)
Sridhar1312
D.D.KORANNE
nafiz
Joey.zhang
mad fridgie
zevacho
Check to the original poster guys and you will find that this was his one and only post and that it is two year old now. ;)
for finding the amount of refrigerant(kg) for a plant just multiply volume of LP Receiver & density of Ammonia at that temperature
