cold storage capacity - m3/ton
Dear all,
good evening.
can you please give me the following data:
- volume required for 1 ton of each product. (m3/ton)
- I referred in Principles of Refrigeration by R.J.Dossat latest versions .But now i lost the detail.
- Now it is not available in the googles.
- I can get old versions of R.J.Dossat only.
- Kindly help.
Thank you.
Jeyakumar
Re: cold storage capacity - m3/ton
It is one upon density of the product.
Each Product? This to do with warehouse storage or?
Not even Ice is consistent enough in terms of how it packs to extend its nominal density to how it occupies space in a cold storage warehouse. The gross density of food stuffs can be found at a number of sources One Below can be found on Web as PDF: http://www.fao.org/publications/card...-1fa03e573deb/
thanks lot for your help....
