Hello.
A few weeks ago, I built my first water chiller using an R-134a LG LX67LAQG refrigerator/freezer compressor: https://fbcdn-sphotos-a.akamaihd.net...59225277_n.jpg
Something went wrong at first, so I ended up wasting most of the refrigerant, and was left with only 20 psi of pressure in the evaporator.
Despite the low pressure, it froze some of the water anyway (until the coil itself froze into a chunk of ice) and worked, but I didn't think it was working quite as well as it should have. 20 psi is too low, right?
There is a problem: So I bought a second can of HFC-134A today and charged it more until the pressure was 55 psi in the evaporator. When I tested it, this time, the condenser got very hot immediately (within a few seconds), the water warmed noticeably and the evaporator also cooled off much faster than it used to. It become noticeably cold immediately, but now it won't freeze, and it is taking long to cool the water.
Could this be because the condenser is getting so hot? It is much harder to keep it cool now, and during these tests it did get hot. The condenser water reservoir pump is not powerful.
LG said that the power consumption is 177 watts, but my Kill-A Watt meter read 200-300 watts before I added the additional refrigerant, and now that I have added the additional refrigerant, it starts at about 340 watts and climbs quickly up to almost 500 watts. Could this be due to the condenser temperature as well?
Is it that the condenser is just getting too hot? Or am I going to have to let out the refrigerant again?
