Anyone have explanation of faulty codes of a Carrier 30ra007?
Bye and thanks
Bye and thanks
www.carrier.com or for you http://www.carrier.it/home.asp
You can download the pdf files for all units!
what fault code have you got?
not sure that the fault codes for that machine are available on the website
Try here
http://uk.carrier.com/products/Product%20families.htm
Lrac
hi, the error code is 15... what i can do?
thanks a lot
15 is faulty discharge pressure transducer. Messured value out of range.
Will reset itself if it comes back within range.
Could be the transducer of the cable is defect!
I know this is an old post but hopefully someone is still watching it. I have a carrier ac unit model number 42QG24 with a fault code of 9. Can anyone help me on this one? Thanks
Have you checked with the Carrier websites listed above ?
I may suggest one more website
Carrier EMEA
