Grasso - 9 cylinder Compressor - Ammonia
Hello all you experts!
Please bear with me..... this may be a long one!
And this will probably sound VERY 'novice'.... because it is!!
I am a software / "machine tool controls engineer" and was recently called to replace a failed Omron PLC controller sitting in a refrigeration compressor control panel.
The customer didn't have schematics of the control panel / system, only hand drawn notes on what appears to be a PLC addition / upgrade to this panel.
Also, there's no record of the program that WAS held in the failed PLC, no software back-up or a printed program.
We have failed to contact anyone who may know the contents of the lost programme. So this is a plea for help / comments / direction / contacts / advice / drawings!? etc.
It was obvious to me on my first visit to the customer, that this was a problem needing specialist refrigeration knowledge, therefore I requested that they contact a refrigeration specialist to assist me with the 'logic' of the process so that I could convert this into PLC 'code' for the replacement controller.
My customer did this, and in the interim period (before procuring a new PLC controller) he advised a 'hardwired' fix to get them back into production (Ice Cream Factory) This involved directly connecting the 'loading stage' solenoid valves to the pressure switches monitoring refrigerant pressure.
I seem to be 'rambling on a bit' so let me first tell you what was originally connected to the PLC controller........
INPUTS....
1 - 'Increase' from a Manometer
2 - 'Decrease' ---------"-----------
3 - 'Relay R2 - Compressor Safety Interlocks all OK'
4 - 'PS1' (Refrigerant Pressures' ?)
5 - 'PS2'
6 - 'PS3'
(The bit in-between is missing! ie. the prog!)
OUTPUTS.....
1 - 'Relay R1 - Start Compressor Motor'
2 - 'SV1 Load Stage 1 Solenoid'
3 - 'SV2 Load Stage 2 Solenoid'
4 - 'SV3 Load Stage 3 Solenoid'
5 - 'SV4 Load Stage 4 Solenoid'
The 'hardwired' temporary mod was to connect the system such that as soon as the motor changed from 'star' to 'delta' SV1 would be energised.
Then wired so that PS1 would directly energise SV2 (Load 2)
PS2 would call SV3 and
PS3 would call SV4.
The system then ran ok for a number of hours, until the temperature got quite low (-0.5bar on manometer) then soon after this the ice that had formed on the compressor suction started to thaw, and the customer informed me that temperature was 'rising' at the 'business end' on the production line!
(sorry for my incomplete specialist jargon!)
The obvious ommission from this 'hardwired' temporary fix is the manometer connections, so while we are trying to find someone to visit site to advise us, can you tell me what effect the manometer inputs should have on the 'loading valves' ? Bearing in mind that the PLC only had control over the Compressor Motor starting and the 4 loading solenoid valves.......
We are having trouble getting the 'specialist' back (too busy elswhere) so in the mean-time, is there anyone out there that may be familiar with this type of PLC modification, a PLC that only has influence over the Loading Valves based on the status of the 3 pressure Switches and the 'increase' and 'decrease' signals from the Manometer?
BTW, please don't SHOUT at me, I realise I know very little about refrigeration theory...... but if you want me to play a tune on a PLC controller, just hum it for me !!
I look forward to your comments.
Regards, Richard.
rlmts@controlit.fsbusiness.co.uk
Re: Grasso - 9 cylinder Compressor - Ammonia
Hi;
This post have been very interesting for me. I´m writting for two things:
1. Is there any web site or papers for learning refrigeration logic, i mean: the most common inputs - outputs?
2. On the other hand, i´m a sales engineer working for Grenco in Spain and my main competitor is York. My question:
Here in Spain York is very aggresive with prices, Is the same outside Spain?
Best regards
Here in Canada the lower price is mycom with others close behind it will make a difference if you are a "dealer" this has different meanings for different manufacturers. I work in sales here.
wesmax
Hello Guys just one query on plc logic for fridge systems having safety switches as inputs to the controller I have always thought this was a no no I have always believed these have to be hard wired so they can not be forced through control logic?
Dave G
Originally Posted by dwrefrigeration
is this Thayers
I dont understand the comment
wesmax
Was This problem at Thayers Ice Cream
yes what is the meaning of this
Hi All,
Sorry for not getting back onto this forum to acknowledge the earlier posts (mind you, I think I started to loose a bit of interest when my post thread was being used to discuss the vitues of various service companies ;) )
But, that's no excuse!! I have mainly been busy elswhere in my area of expertise (Machine Tools)
Yes it was Thayers, but it was back in July 2003.
They have since moved from Cardiff up to a new site and factory in Cwmbran.
They now have their own controls engineer/electrician/technician, and I haven't been back there for a year or two now.
Regards Richard.
Once again, sorry for not acknowledging earlier.
Richard
I was the refrigeration engineer who met you on site to hard wire the panel.Thats how I knew it was Thayers
David Whitcombe
Originally Posted by torque
Calders it's not Richmond Frozen confectionary they don't have a plant in Wales and they have a contractor working along side there own engineers
York Refrigeration
Andy, Why was York brought into this discussion?
Marc, you may have grievance with a local York office but I would ask you don't tar every branch with the same brush.........you may show yourself up (no change there then):)
MMMMMMMMMM lot of things ring bells here.....
I used to work for a certain little industrial compressor manufacturer from denmark.... Then a certain afore mentioned American company decided to buy them out.... Stuck it with them for a few years and because we actually retained our identity and individuality it wasnt to bad.
But the bible EBIT soon became to much to bear and it was time to go
It should be a no-no for HP, LP and Oil safety switches, plus any interstage protection. The same for temperature protection stats. This is if the compressor can be run on hand, as running in this mode may by-pass normal control routines in the PLC. It is not unknown for a PLC control to crash through supply voltage faults for example. Someone then comes along to run a machine on hand "until someone technical gets here".
However, if control routines are inserted to ensure ANY fault condition met ensures total shutdown then maybe OK, but if it was ammonia, I'd go for belt and braces. To be honest, I've never come across a plant without hard-wired safety's.
Steve
We've recently taken over maintenance of 2 Dunham Bush chillers (240kw each) and all safety measures were through the software :eek: (we've put in hard wired LP and frost stat safety switches so far - looking at other options at the moment)
Hi Richard,
Have you resolved the loading and un-loading of your Grasso compressor? If not is the compressor model a RC 63 11 or RC 63 12?
hi , here in india we are dealers of mycom screw compressors.our competetors are supplying the grasso compressors.i am marketing engineer for mycom so i want to know the advantantages of my com screw compressors over grasso comressor.
Dear Sir,
I need some used Ammonia Compressors. Please note detail & send me best
possible rate C&F Karachi Pakistan.
Grasso RP-412 Ammonia Compressor 4 piston to 6 piston.
Made in Netherland.
Thanks & best regards,
Tariq Kaleem
(Managing Director)
FAIZ TRANSPORT
Phone :+92-41-8507171
Fax: +92-41-8506855
Cell: +92-321-2663355
Cell: +92-300-8669555
tk@faiztransport.com
