Can anyone recommend a good one?
Looking for somthing that will work in a busy workshop with a low pressure system (2-5 bar g).
Hi Derek,
I don't use them but here are a few sites that might help you:
http://www.logis-tech.co.uk/ultraset.htm
http://www.reliableprocurement.com/M...egory_Code=ULD
Good luck
Chemi
Accutrak makes a nice one. The trick with Ultrasonics is knowing when and when not to employ them or trust them. Accutrak is great on vacuum leaks and most ambient noise is screened out. But low pressure leaks are not an ultrasonic's forte, unless you are in manufacturing and using tone generators, etc.
A Belgium manufacturer http://www.sdt.be/
It's a 20 years old spin-off of a very famous university
