Hi guys,
Have a Liebherr No-frost fridge/freezer fridge 5c, freezer only -10c, display bleeping, R600a single pot has a 3 way valve.
Suction pipe next to compressor frosted up, enough gas in system.
Be greatfull for any help.
Hi guys,
Evap iced up?
Evap fan not running?
Not condensing enough?
Nice fridges those.:)
Thanks is it no a board problem
Their UK distributor is Coolectric, they should be able to supply a service manual or maybe have an idea of what the problem is:
<http://en.liebherrinfo.nl/service.php>
It might have extra controls to enable it to work properly in lower temperatures (-5c), perhaps the FF is operating as if the ambient is much lower than it is.
In which case check for an extra thermostat on the outside of the cabinet somewhere and how it affects the FF.
cheers,
Pete.
Does this mean the evap is not iced up?Quote:
Must be overcharged then?Quote:
Make sure the fan is going the right way, and the blade is on the right way.
Thanks guys you have been very helpfull you Know what these frost free are like a right ******* pain
Chillin Out,
Not overcharge frosted on visit.
Thanks anyway.
I think your evaporator coil is iced up , or evap fan not working
Check defrost cycle
