panasonic cu-re12jkx-1 error h11 ,no communication
Hi ,i have a problem with this unit ,i suspect it is outdoor pcb .Is there some component that could the problem and it is replacable ? The whole pcb is expensive and would be better to buy a new unit .I have checked few resistors and capacitors on the com terminal 3 but couldnt find anything wrong .I hear a lot of this units have this problem .
In one machine like this a had a problem with power module on outdoor pcb and manage to repair it .Maybe someone has a solution?
Re: panasonic cu-re12jkx-1 error h11 ,no communication
Found this:
If all connections are good, than measure beteeen them on the DC range, and it should be fluctuating between 20 and 50 V DC
If it is, than it may be a faulty indoor PCB, if it is not, than disconnect number 3 at the outdoor unit, and measure what comes out of the PCB on 3, in reference to number 2,it should be about 20 - 70 Vdc
If this voltage is not there, than the outdoor PCB may be faulty
[COLOR=rgba(0, 0, 0, 0.870588)]
[/COLOR]stefs cruiser posted on this forum, in relation to some other panasonic model .Is this also aplicable to this model?
